跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 - Audio issues
Hi, I have an iPhone 6 that had contact with water. I used alcohol to clean all connectors and brushed areas that had corrosion and the phone works now. The water seemed to enter from the top, since I found no trace of corrosion near the bottom. Everything functions properly except the speaker. If I raise the volume past the halfway mark it cracks and goes mute. A reboot resolves the issue until I raise it again. Could it be an issue with the dock connector, the speaker itself, or the audio ic U0900?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It could be any combination of those things. Only way to know is to test fresh components
Sorry i couldnt be more help
这个答案有帮助吗?
得分 1
添加一条评论
Yes, purchase a new dock connector and speaker , they are cheap enough and easy to fit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Benjamin Hong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 52
