跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
772 个问题 查看全部
Vertical lines on screen
Hello, to my macbook pro 15 ", vertical lineas appear one on the screen, I have read thereabouts that if I connect it to a television and the same lines go out probably it is the graphical card but in my case it is not like that, does not show these lines in external monitors, which it might be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
They disappear for around 10 minutes and they change color, specially from violet to a light gray
完成的
添加一条评论
3个答案
最有帮助的答案
Try re-seating the LCD cables, if that does not fix it you will need to replace the LCD or top case assembly. Has it been recently dropped or damaged?
这个答案有帮助吗?
得分 1
4条评论:
Not that I know jaja, I will try to this and hopefully this will work, I hope so, it is incredible how an expensive machine as this one can suffer this stupid damage, thanks dude.
完成的
Another thing, sometimes the lines disappear, do you think this might be something of the LCD cables or more just like a damage LCD panel?
完成的
Do they completely disappear, or just partially? Post a picture.
完成的
Down there is the picture
完成的
添加一条评论
这个答案有帮助吗?
得分 0
1条评论:
Clean the screen connectors with rubbing alcohol and make sure there is no dust.
完成的
添加一条评论
This is a TAB issue. Please see this answer There is faint vertical green line on the screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Erick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,936
