跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
问题已关闭
dropped iPhone 3GS now no power
I dropped my 2 year old iphone 3gs on the concrete from about 2-3 feet off the ground. When I picked it up the power was shut off and would not turn back on even after trying a hard reset. I was told to make sure none of the ribbon cables popped off and they have not. I also followed the fix it guide on how to remove the logic board and reinstall as this can sometimes fix the problem but no luck. itunes or a computer does not recognize the phone and unfortunatly the laptop that i did my last sync on is broken so I desperatly want to fix it to retrieve all my info. please help!!! many thanks ps i did put a volt meter on battery contacts when i had it apart and battery is fully charged, Could my logic board be put in another working iphone 3gs to retrieve info?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You will need to put you logic board into another iPhone first. From there, you can make a backup and figure out what else is wrong.
-Look on board for any obvious signs of damage or broken connectors.
-Look at dock connector and check for bent pins
-Test LCD. LCDs can go blank giving a false sign of the phone appearing off.
Does the computer recognize a device is plugged in at all when you connect it to the computer?
Was it jail broken?
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,405
