跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
ear speaker not working after screen replacement
Hi i had issue with iphone 7 plus after replace screen client came back and said ear pice not working i bought ear pice and few flex cables and replaced as every one said 1 flex cable ear piece is working no camera 2 nd flex camera works not earpiece any solution????
i have tried hard reset
i have tried replace flex cable
i have tried little tape inside
Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Are you getting parts for a reputable seller? It sounds to me like the part you are trying to replace is faulty and the replacement parts are not that good. Some functions are working and that is good letting you know that the hoard is fine. This is because you say it works with one cable and not the other. I would like at find a replacement for a reputable seller such as iFixit.
iPhone 7 Plus Front Camera and Sensor Cable
Simply use the same ear speaker that you know is working. This should solve you problem. Also makes sure the cable is lined up perfectly making contact with all the ear speaker connections.
iPhone 7 Plus Front Camera and Sensor Cable图片
产品
$29.99
这个答案有帮助吗?
得分 1
添加一条评论
As the iPhone Guy suggests, you need known working test parts to effectively troubleshoot. Then once the problem is found you can just replace the faulty part.
这个答案有帮助吗?
得分 1
2条评论:
It's finally fixed by the 4 th cable replacement
完成的
So basically it was the bad parts
完成的
添加一条评论
Try another flex or an original flex a lot of those flexors are bad from the factory
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vihar Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,618
