跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
465 个问题 查看全部
Trackpad totally dead, any ideas why.
Hi Guys,
I've got a A1398, MacBook Pro 15" 2.2 GHz Core i7 - Mid 2014 system with 2 issues: a bad battery and a totally disabled trackpad.
I've tried all possible troubleshooting and diagnosing I could with no luck.
I ordered battery and new trackpad and swapped them both, but the trackpad still not working.
All the settings inside the computer checked. In the end, I took a backup and re-installed the OS, but the problem remains!
Can anybody help me with this issue?
Update (06/05/2017)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
The cable looks clean and I don't see any damage. Even still this cable is likely the problem. You'll need to see if a replacement fixes things.
完成的
Ok, actually I got a trackpad without cable. I don't have any one to test with. I will se if I can find one. So you thing this is not a motherboard issue?
完成的
Don't think it's a logic board issue.
The cable is not passive (see the chips on it) I suspect this is the issue you're facing here a burnt chip on the cable.
完成的
Hi,
Thank you for the notes and the help. The TP cable changeed and the macbook ok now.
完成的
添加一条评论
1个答案
已选择的解决方案
Carefully disconnect the trackpad ribbon cable and take a set of clear pictures of the connector ends (both the ribbon & logic board) and post them here for us to see. It sounds like you have a damaged connector.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
MKA 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 376
