跳转到主内容
Released on September 1, 2013, the Nerf RapidStrike CS-18 is a fully-automatic blaster with five tactical rails, motorized automatic firing, and a stock clip that holds up to 18 darts.
7 个问题 查看全部
Why my rev trigger pushes very hard and gets stuck often?
My Nerf Rapidstrike was in a cupboard for a year(no one touched it) and then suddenly i wanted to shoot with it and the rev trigger got stuck in the gun. PLEASE HELP
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Ok, so you need to take apart the gun, simply remove the screws and pry it open, you want to remove the stock and be carefully of the top as it is wired, remove the wiring on the top half of the gun carefully (positive battery connector) then look to the right of the gun and find the switch you are having troubles with, try to get a hot glue gun and carefully melt some plastic around the trigger/button, then remove the button/trigger, give the plastic part a good thorough clean then put it back carefully make sure you don't damage anything else, replace the covers for the switches if there are any, then put back the positive battery connector on the top half. Put back stock. Put halfs together do not screw together yet, test without screwing together, if it works then screw back together, if not reply to this and I will answer.
P.S. make sure you pry open the 2 halves of the gun when the screw side is on top. Don't open it upside down(not a good thing to do)
这个答案有帮助吗?
得分 1
2条评论:
Sometimes just helps if you open the gun and then close it, same thi happened to my rapid strike and stryfe after I modified them
完成的
well i tried to open it and the problem is also in the motor itself so thx for help i will have to get a new one :( #FixHasbro
完成的
添加一条评论
Remove one bullet then take out the clip and press the bottom white button inside the clip slot
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Feodor Shevlyakov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 26
总计 1,584
