Kickstand welded and will not budge
I have never seen a kickstand that was welded to the frame. Once down it will not return to the up position. I have no idea what to do.
@eddiem, Eddie, You may be able to lube(oil) the hinge/spring area of the kickstand to get it moving more freely if stuck. You are right, it is unusual for a kickstand to be welded to the frame of bike. If all else fails the kickstands weld may be able to be cut/ground off with a angle grinder and then stand can be replaced with a new one. If not comfortable/wanting to remove the stand your self perhaps pop into a local auto repair/autobody shop and have them remove the welded on stand for what I would think would be a small fee. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 670
2条评论
Could you please take some nice pictures?
在已经存在的问题里加入图片
由 George A. 完成的
are you sure theres not some sort of safety clip to keep it from releasing when you don't want it to
由 Jimfixer 完成的
