How can I swap out the home buttons with ipad air digitizer?
I replaced the digitizer on 2017 iPad and want to know if I can also swap out the home buttons?
The big one, is the Air 1 digitizer cross-compatible?.
Also, check here.
I haven't confirmed this personally so caveat emptor.
这个答案有帮助吗?
Answer: yes.
The original iPad Air Digitizer works as a replacement. Be careful when removing the cracked or bad digitizer as the home button comes off in the same way that the original Air does. The 2017 model has sensors on the cable for TouchID. Simply take the original home button off the 2017 model and swap it onto the replacement digitizer.
这个答案有帮助吗?
Hello, ran into this same issue and here is what I found:
Basically the digitizer works, but the button does not from the iPad Air 1st generation. Read my full post here regarding this same question:
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,849
3条评论
Most of us have not seen this one yet. Would you let us why you do do this?
由 mayer 完成的
Well, in my case my screen shattered and so removed the screen but also ruined the home button in the process. So I simple removed the old home button and have ordered a new one. Hopefully it'll go back together no problem fingers crossed. I'll update when I get my new home button.
由 Noah Pritchett 完成的
touch id will not work if you replace home buton
由 asears 完成的
