跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
I have pushed very hard a a needle in the top microphone hole
Hello.
I wanted to take out the sim card of my galaxy S8+
I made a mistake and i put a needle in the top microphone hole. (the one next to the sim card hole)
i pushed the needle very very very hard... until i see that it was a mistake.
Do you think this could cause damage to the microphone?
Thank you for your answer and sorry for my bad english.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Any news on this?? I'm afraid I just did the same thing
完成的
添加一条评论
2个答案
最有帮助的答案
I would say theres a very likely chance you damaged the microphone if not something else
这个答案有帮助吗?
得分 1
2条评论:
Thank you
is there a way to check if it is damaged or not ?
完成的
Its not an easy one but recording a video with audio may show any problems. That top mic is also used for noise cancelling which isnt so easy to test
完成的
添加一条评论
I did the same the first time I got it. Mine still works. Tested it using the Voice Recorder interview option which uses both microphones. Then I spoke at the top one and then at the bottom one in roughly the same dustance and loudness.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Parisien 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,981
