跳转到主内容
This Firestrike Elite Blaster was released in 2013. In addition to its plunger activated firing setup, it features laser guided aim. The blaster originally came in blue, white, gray, and orange but a second color scheme features orange, white, and gray.
6 个问题 查看全部
Back screw will not budge
So I'm attempting to mod my first ever Nerf Gun. I decided to go with something relatively cheap; the Firestrike Elite.
However, before even getting to the inside of the gun, I've encountered a problem. The screw located under the top rails to the back will not move. I've successfully taken out all other screws, but this one will not budge. My screwdriver simply glances over the bumps of the screw, and I can never get a good hold on it. I managed to move it about a quarter rotation once, but that's it.
Can someone please give me some tips?
Thank you,
JR
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@dkinger, JR, Hopefully the screw head is not stripped. Try heating up the area with a heat gun/hair dryer right where the screw is threaded in, get it hot to the touch then try removing the screw. This should expand the area of the screw a little to allow for removal hopefully. The only other thing may to use a drill and small metal bit(a wee bit larger then O.D. of threaded portion of screw) and drill the head off screw and then disassemble and use small vise grips/pliers to turn out remaining screw shaft. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Justus Rodriguez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 734
