跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
iPhone 6 plus screen unresponsive
I have replaced a screen on my iphone 6 plus and whenever i connect my touchscreen cable, the screen goes wild with lines all over so nothing can be seen, when the lcd cable is in the screen works fine until the touch cable is connected. Could anyone fix this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Check the logic board connector where the digitiser is connected and make sure there is no damage to the pins, also make sure you are connecting the digitiser connector correctly as this issue can happen when it is misaligned. If the board is fine and the screen is correctly connected then it is likely to be a faulty assembly, you'll need another to screen to confirm this.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
thepan10 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 204
