跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2261 个问题 查看全部
Kill Switch if update to 10.1
Has anyone had any issues with the iPhone 7 repair and home button not working? I spoke to someone at Apple. They said they designed a Killswitch if they have a certain update on their phone the 10.1. if theres any repair done to the phone it does a kill and the home button won't work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
In my experience, if you have a non-apple home button then you shouldn't upgrade. I've attempted to do so and ended up with an iTunes error -59 (I believe) that I couldn't get to go away no matter what I tried, including updating without any home button.
However, I have upgraded a hundred phones with everything from battery, to screen, to charge port replacements that worked just fine. Just stay away from replacing the home button at any cost.
这个答案有帮助吗?
得分 1
添加一条评论
What repair did you conduct on the phone? Apple did put a software kill switch on the home button itself if it were replaced, but I havent seen any other repair cause that. However , that being said, I did have a repair end up with no home button function after replacing the screen. I switched to another screen and the issue was resolved. Remember your screen is like the middle man between your home button and the logic board. The button plugs into the screen and the screen plugs onto the logic board. A cheap or faulty screen can contain low quality components that affect the signals your phone and home button are sending. Ive seen this issue once on an iPhone 7 and several times on 6s and 6s Plus models that have the button connector integrated into the backlight assembly. Hope this helps,
Jake
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
troy parcelles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 82
