跳转到主内容
no sound from right speaker and poor sound from left speaker
My right speaker is not putting out sound. The left speaker is working but sounds very tinny. I am guessing the subwoofer is not working either as the sound is so thin. I tried replacing right and left speakers and the subwoofer, but everything is the same. The connections all seemed to be secure.
I don't think it is a software issue. I have tried many things including resetting the SMC and PRAM. The problem is the same whether I boot into OS 10.6.8 or OS 11.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
The connection of the right speaker is quite tight and tricky. In my experience it can sometimes disconnect when reseating the logic board. All in all, the acoustic performance of this speaker system is lacklustre. It's a fact. I use Bongiovi DPS system wide audio post-processing software to slightly enhance that poor performance. It works well. https://bongiovidps.com There are other alternatives in this space, but I found this working best for me. Hope this helps.
这个答案有帮助吗?
得分 0
2条评论:
I tried out Bongiovi DPS. It raises the volume and seems to boost the high end, but still sounds blown out.
完成的
In the settings panel, there is an option to disable volume boost. Try the different profiles. I found "MacBook Turbo" working for me best.
完成的
添加一条评论
添加你的答案
gaijin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 286
