跳转到主内容
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 个问题 查看全部
1983 FA50 Suzuki Carb continues to leak gas
This video and pic was taken when I initially found the problem. Afterwards I took the carb off and disassembled it, cleaned it out and found sand on the tip of the float needle. As I was doing this, I checked the fuelcock for a leak. I turn it on the different sets and it flowed when it shouldve, and it cut off when it should've just fine. I then put the carb back on and got it running perfectly for only about 7 seconds, then it started to leak again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@fa50suzuki1983, Victoria, It appears to be leaking from the overflow nipple. You may want to consider replacing/rebuilding the carburetor if you have already found dirt in it. Could be the float needs to be adjusted to stop the flow of gas from overfilling the carbs bowl, bad/damaged float needle or seat(replace both perhaps). Find below links to your service/repair manual, schematics of carb. and possible replacement parts, which you can also do a search on perhaps for better pricing, last link are various guides and info. available on ifixit site that you may also find of interest. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://projectmopedmanual.info/manuals/s...
https://www.cmsnl.com/suzuki-fa50-1983-d...
http://www.ebay.ca/sch/i.html?_pgn=1&isR...
Suzuki FA50 Moped
这个答案有帮助吗?
得分 4
添加一条评论
I've taken out the float PIN and put a cut Q-tip in my drill like a bit. Shine the inside of the tube with some polish on the Q-tip. This will give you the cleanest seal possible. I also put s kill switch in the line.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Victoria 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 3,089
