跳转到主内容
Second generation of the Ford Focus.
95 个问题 查看全部
How to replace CODE PO193 FUEL RAIL PRESSURE SENSOR 2007 Ford Focus
I have a 2007 FORD FOCUS 2.0 and according to Smog Check station it didn't pass. So, had to go to AUTO ZONE and had them test it and the code shows P0193 FUEL RAIL PRESSURE SENSOR. I have about 298,000 miles on the vehicle. How to replace it.. FORD Dealer estimate around $500 to $600.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
I find when you have a P093 code its usually caused by a plugged fuel filter. Start there reset the codes and drive it for a day if the code comes back move on to the fuel pump. If a pump has been pushing fuel through a clogged filter for some time it can tend to loose pressure so check the pressure on the rail . If you do need to replace the sensor this video will help
https://www.youtube.com/watch?v=h8f01Et3...
This is a good place to buy
http://www.rockauto.com/en/catalog/ford,...
Hope this helps
这个答案有帮助吗?
得分 6
3条评论:
I replaced my sensor and it only cost $10 on line. 2005 ford focus
完成的
Where online did u purchase the sensor?
完成的
@nazare rockauto.com has all the sensors you'll need
完成的
添加一条评论
@vadford2007 remember that there are a few causes of this error code. So you do want to make sure that you check all of it:
Faulty Rail Pressure (FRP) Sensor
FRP harness is open or shorted
FRP circuit poor electrical connection
Faulty Fuel Pump
Faulty Fuel Filter
The FRP sensor is located top center of the fuel rail to the injectors. It has a wiring plug and a vacuum line connected to it. If you post some images of your engine, I am certain we can point it out for you. To replace it, you should always first release the pressure on the fuel line. You can accomplish this by removing the Fuel Pump (FP) control module fuse in your fuse box. Then start the engine and allow it to idle until it stalls. Once it stalls you can try to crank it over a couple of times for any residual pressure. Disconnect your battery (make sure that you have a radio code just in case your vehicles radio needs it) Unplug your vacuum line and your electrical plug. Then use a wrench to remove the sensor....
这个答案有帮助吗?
得分 6
添加一条评论
添加你的答案
DOLLY 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 56
总计 23,922
