MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
4071 个问题 查看全部
DVD Drive No longer works
The drive will accept dvd and cd but just spins them for a bit and spits them out. I am out of warranty so is there an easy way for me to fix it and if not how much will Apple charge me to fix it?
Thanks In Advance
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
5个回答
已选择的解决方案
It's time to replace the drive. Apple would charge about $30-$60 an hour but it's an easy DIY.
这个答案有帮助吗?
按维修分数 -1
评论:
Apple does not charge for labor "by the hour". They use tiered flat rates for labor. This type of repair is considered Tier2, which means labor will be about $150, plus the part.
添加一条评论
最有帮助的答案
Yup, your optical drive is defective. If you are feeling adventurous I would say it's an easy DIY replacement.
From the ifixit website I have found the part you need:
MacBook 8x SuperDrive
And the ifixit take apart guide (assuming you have a Macbook Core 2 Duo):
Installing MacBook Core 2 Duo Optical Drive Cable
If DIY isn't your thing then I would (in my opinion) not take it to an Apple store because they do charge a premium for labor and repair. But they are usually the most reliable. So if money is not really a problem, go for the Apple store. But I would search around for an Apple Authorized Service Provider to see if they can do it for less.
Good luck!
这个答案有帮助吗?
按维修分数 2
添加一条评论
Sometimes the optical drive is still functional but needs a clean up to do efficiently his job. When there's dust (or if you smoke, tabaco fume residue) on the laser lens the laser beam may not correctly read the disk and the result is that the optical drive will spit it out. So if your intention is to replace the optical drive yourself you could open the optical drive (4 screws) and clean the laser lens with a Qtip and alcool (apply a very small amount of alcool on the Qtip and clean the lens without applying too much pressure on it then dry the lens with the other Qtip end). It's also a good occasion to clean the optical drive mecanism with compressed air and check if the black textile protection at the entrance of the drive is well glued in place.
这个答案有帮助吗?
按维修分数 1
添加一条评论
thank you guys i'm going to call apple and find out exactly how much it will cost. I'll also read up on the DIY
这个答案有帮助吗?
按维修分数 0
评论:
Did they ever tell you how much it might cost? I just called and they refused to give me any type of estimate for the same problem.
添加一条评论
If you don't want to replace the drive yourself, compare Apple's price with iResQ.com. I've had good luck with them in the past. Looks like they want $298 for a MacBook Superdrive replacement, ouch, though that includes shipping back to you.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
bob616 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 24
过去的30天: 93
总计 10,988
