跳转到主内容
Fixes and troubleshooting for all kinds of UAV problems.
770 个问题 查看全部
Apex x100 Camera won't record
Everything about my drone works fine except for the fact that video and picture won't be recorded onto my sd card. The drone recognizes that the sd card is there, I've tried multiple different mini sd cards. The drone responds to remote commands and flashes lights when input is made, and I have visual connection from my FPV screen. I've opened up the camera and all wires are connected as far as I can tell. It just wont record anything, if you know what might be wrong please let me know
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
My Warhawk drone won’t go past step 6 on setup &synchronization
这个答案有帮助吗?
得分 0
3条评论:
Same here....everything calibrates except step six at the 45 degree turning...the lights won't stop flashing
完成的
It comes with its own memory card already
完成的
mine either, does the camera angle button work? mine does not change the camera angle and the one button take off does not work...
完成的
添加一条评论
Did you check what format the card is in? I,me not sure what the drone requires I think it is Fat32. That is what most memory cards are
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Reuben 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 237
