跳转到主内容
The Roku 3 (Model: 4200) is a third generation streaming device released on March 5, 2013. Connect to any television or video display with correct input connections to stream available content.
12 个问题 查看全部
AFTER accessing my Wi-Fi, my Roku 3 can't find "MY NETWORK".
My Roku 3 worked great for a couple months, but eventually it "froze up", so I had to power-down and restart it. Now, when it starts up, the first thing it does is search for my home Wi-Fi ....WHICH IT FINDS AND CONNECTS WITH.
BUT THEN it starts searching for "my home network"....which I can't understand, because:
(1) it never did this step in the past, and
(2) if it is already connected to my Wi-Fi, then it ALREADY IS connected to my home network.... ISN'T IT ??
In any event, after searching for "my home network" for a bit, I am told that "it can't find it", and the whole start-up fails, and I just have to repeat the steps I just described .... and I obtain the same exact unsatisfactory result.
I just keep "going in circles".
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Your home network and wifi are separate. Ethernet is preferable to wifi. Do you have a CAT5/5E/6 cable? If you can, use it. If it's connected to home wifi, that means it's connected to the router with a wifi signal. Your home network is what all devices connect to and share data with. Try restarting your Roku again, this time using the option in settings. If that doesn't fix it, a factory reset should. Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sam nicolosi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 93
