这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4547 个问题 查看全部
iPhone 6 error 56
I have an iphone 6 that was updated thru settings to latest iOS and failed and needed to be restore with iTunes. I did so like 5 times now and it keeps failing with error 56. I've tried new cables, new dock connector, latest iTunes, tied both windows and Mac OS but it keeps giving the error. what causes this and how can I fix it? Thanks
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
评论:
Hi I have the same problem on iPhone se and i fixit. What i was try to do was remove the battery connector to drain the power from the phone but as i use screwdriver to remove the conector there was sparcle so I thing the phone reset as when i try to turn the phone on it show low battery logo and after i restore the phone and it work.
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
Asked and answered:
What is (unknown error 56) iPhone 6
这个答案有帮助吗?
按维修分数 4
添加一条评论
100% solution
NFC IC REBALL & JOB DONE
100% TESTED
这个答案有帮助吗?
按维修分数 1
评论:
hello brother
i have done for your idea
very thanks
but my iphone 6 done for error 56 but wifi not work it's Gaye
添加一条评论
Yeah from days of research and a @%^$$@$ iPhone that is still stuck, I have concluded that it is either the NFC chip (which was working perfectly fine, I have no idea why it died), or my touch id button (tried original and spare ones, original is cracked and touch id may no longer work, but chip on it is in working condition, or my cables/$@$*!& wiring. Someone please help me before I hang myself. Why are androids so easy to fix and iPhones stubborn @%^$$@$# who can't take the slightest beating from command prompt or terminal? Its always the iTunes $@$* that gets me every time. Anyways I am buying a new iPhone tomorrow with hopes that I can have a working phone, but chraiglsist seller isn't responding and I am getting nervous and sad. &&^&^$^ !&&* I am killing myself.
这个答案有帮助吗?
按维修分数 1
评论:
I relate in many ways
添加一条评论
sometimes error 56 is caused by the power supply of camera on iphone 6.
exchange the both camera(which i dont think it would works) and check the cricket might fix ur problem.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
CAB 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 9
总计 3,533
