跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Why is the unit not turning on?
I fixed the sensor flex PCB and after that, it was fine. But after I put the unit back, I realized I forgot to put the rubber holder for the ambient light sensor on, so, I put it on and after that, the phone will not turn on anymore. On that same day, I was able to detect the device on my pc and charge(?), but after a few days, it will not turn on at all and pc won't be able to detect it. I checked the voltage on the battery, it is 2.95V. Any suggestion of how to fix it? I am only fixing phones for friends and I don't have a ton of equipment. This is actually the first time encountering such problem. The other phone I fixed along with this one was fine.
Maybe the battery's problem? I'm not sure. The screen and touch and touch ID are fine when I placed the whole assembly on another working phone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I do believe 2.95v from the battery is to low to power on the phone. It would require closer to the area of 3.4v to power on the phone. So it could possibly be a failing battery. It may be a number of things but it could not hurt to start by trying another battery first as the one you have will not power on the phone due to not enough voltage being supplied to the motherboard. May also be the charge port is damaged or needs cleaned and your battery has discharged below the required voltage to power on the phone due to a damaged charge port.
这个答案有帮助吗?
得分 2
3条评论:
Well to be exact at least close to or above 3.7V for the phone to power on. Could be something heating up on the board causing a short to drain the battery quickly.
完成的
Yes could be a short. I was playing with my DC bench top power supply and it was with the iPhone 6s not the 6. It boots the phone to the lock screen at 3.5v. The iPhone 6s will turn on but not boot at 3.2v. Most phones that have a battery with a nominal voltage of around 3.8v boot at about 3.4v to 3.5v on my power supply. Thanks for the comment though as I don't have a iPhone 6 here I can play with that with take more than 1v before it trips my power supply due to a short in the motherboard.
完成的
I charged the battery to 3.9 now with a charger. And it still won't turn on. Any ways to back up the whole system, since the data is the most important part. Thanks! It might be because of a short. Now the battery basically stays there.
完成的
添加一条评论
最有帮助的答案
Can you explain what you mean by sensor flex PCB? Is that the front camera ribbon cable flex assembly that goes behind the screen?
这个答案有帮助吗?
得分 2
1条评论:
Yes! That's the cable.
完成的
添加一条评论
添加你的答案
Tuohang Zeng 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 116
