跳转到主内容
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
83 个问题 查看全部
Is the grey connector cap important?
I broke two "tooth" from the digitizer connector CAP (the grey thingy) while trying to change it. is it why my new digitizer doesn't work too ? or is the new one also damaged because I see some scratch on the ribbon cable... ?
thank you all :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If the latches on the motherboard are damaged, you can always try applying pressure while turning the 3ds on, because that ensures that there is contact. If that works, you can put some paper or tissue in between the connector and housing to keep pressure on the connector
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
junnujs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 51
