跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
I get NO SERVICE msg in my phone
i have a iphone 3G 8 GB. i am finding a problem with my phone, which is that my iphone gives NO SERVICE msg most of the time. When i put the same sim card in any other mobile i get good signal. i have tried a lot of things but nothing is working. what to do? please advise
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
6个答案
最有帮助的答案
Have you tried a different sim card in your phone? If so and the problem still occurs, u might need to get a new antenna flex cable for your phone. If they do not sell on ifixit.com, try ebay.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same issue on the same iPhone.
Discovering on all around forums and internet that may be the baseband has been broken.
I have replaced the antenna assembly two times and I'm still getting the NO SERVICE msg.
So the issue is not linked on the antenna flex cable or antenna assembly.
Now I'm trying to get a new phone logic board that I hope to find.
I advice you to try this.
Step 1: Try to downgrade your FW to the 2.x version
Step 2: Modify your fw in order to install cydia
Step 3: Download FuzzyBaseband from cydia
Step 4: Try to downgrade your baseband
I hope you will get more luky then me.
这个答案有帮助吗?
得分 0
添加一条评论
Is your phone jailbroken?? i had this problem... it can simply be that too much stuff is being used, i dont know how it works but i just reset everything to look factory and my signal come back-
for a temporary fix, switch 3g off and then turn aeroplane mode on then off, will force the phone to search for signal.
这个答案有帮助吗?
得分 0
添加一条评论
I mean that he tryed to open the iPhone assembly and after re-closing it he got this prob.
这个答案有帮助吗?
得分 0
1条评论:
In which case you have probably not connected ribbon number 5 correctly.
完成的
添加一条评论
He probably has to ensure that no5 is plugged-in correctly, but in my issue I have re-plugged that cable so many times and each time the phone gave me the NOService msg.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue since i replaced my iphone 3g 8gb lcd and screen my phone fails to get signal except on 3g occassionally, it sometimes comes up with normal signal if left for a while but still doesnt make calls, and/or the call fails all the time. also wen i do get to make calls on the 3g people fail to hear me after about a minute or so......help! ive tryed everything! thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ashima 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,770
