跳转到主内容
修复你的物品
维修的权力
商店
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1556 个问题 查看全部
MagSafe blinks green and doesn't charge?
The other night I noticed my MagSafe blinking green for a second then off for a second intermittently (now that it's dead it blinks every two seconds or so?), didn't really think much of it until I opened my laptop the next day and saw the battery was down to around 60% even though it was plugged in all night. Tried playing around with the charger, tried different outlets, tried resting the smc, took the bottom case off and unplugged the battery and plugged it back in, and nothing seems to work. I thought the battery might be done because while trying to fix this I noticed I was over 1100 cycles now and when I clicked on the battery icon it said to replace it soon, but even still the computer should work fine while plugged in shouldn't it? Curious if anyone knows what's going on and what could fix it, hopefully for free as just last week I spent a bit of money to replace the hard drive cable and don't really want to put much more money into a computer if one things gonna go wrong after the other.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
2个回答
最有帮助的答案
Review this Apple T/N: Apple Portables: Troubleshooting MagSafe adapters. If needed clean the contacts of both the MagSafe adapter and the computer with a cotton Swab (Q-Tip) slightly dampened with 85% or better isopropyl alcohol.
Update (05/19/2017)
OK, I think you have either a bad battery or the charging logic is damaged.
Lets open the system following this IFIXIT guide and disconnecting the battery: MacBook Pro 13" Unibody Mid 2012 Battery Replacement Stop at Step 4. Now Plug in the MagSafe adapter are you able to start up the system?
这个答案有帮助吗?
得分 2
评论:
I've tried pretty much everything on that list and now its working.
I left it plugged in over night and it managed to charge up to 36% and the MagSafe is a solid green, but as soon as I turned the laptop on it started blinking again and only charging every second...
完成的
How did you solve the problem?
完成的
添加一条评论
Did you try disconnecting the battery and then plugging magsafe in?
这个答案有帮助吗?
得分 0
评论:
No I wasn't able to start the system with the battery disconnected.
完成的
添加一条评论
添加你的答案
chris schlief 将永远感激不已
浏览统计数据:
过去的24小时: 6
过去的7天: 82
过去的30天: 339
总计 17,643
