key board malfunctioning & Numpad
on the lock screen of windows 8.1, automatically entering the log in button. simultaneously its deny to log in & again entering the log in button because the password is not given. when I hit any key on the key board then its stopping to do that problem. And i put the password & log in. On the other hand the enter key in number pad is not working.
Whats your issue? Also is num lock on? And what key did you press to type the password in?
由 Cameron 完成的
Any key I press, it stops auto loading password. If I unplugged the laptop key board & use a external keyboard there is no problem.The assembled key board is working well rest of the time.
Number pad enter key doesn't work even the num lock is off or on.
由 Kishor Datta 完成的
It was not an answer. It was the same problem I had with no answer.
由 gillman61 完成的
