跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 个问题 查看全部
blue light then popping noise
Hi,
I brought a faulty 2ds thinking it'd be an easy fix.
I opened it up, checked all the ribbons and they all seem well seated, tried the wifi card & I still get the pop noise.
I looked at the screens with some light & they appear to have some cracks, I haven't taken the motherboard off yet.
Any ideas on how to fix it?
Also, on opening the gate on the home button ribbon I pulled off the grey gate, should it operate fine without it?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Usually breaking the ribbon cable latches is bad, but i don't think the home button should be that bad (try applying pressure while booting). Sometimes components fail without you being able to see (my n3dsxl wouldn't boot because of a non-working screen -no cracks, no rips in the cable), so consider getting a 2ds for parts, so you can test what's wrong with it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jack 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 854
