跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
Can't find any compatible battery
I've tried to order roughly 5 batteries now, ranging from different buyers and APNs, 616-0718, 0720, 0721, 0728, all of them do not even light up the screen as the old 616-0722 battery does (which has a low voltage, unable to boot, shows a please charge screen with lightning cable). I have tested with other charging ports as well. The problem is I cannot purchase another 0722, no matter where I try, ever after I spend 100$ on a specific eBay advert that claims to only have that APN.
All the other sellers are convinced there are other compatible batteries, but so far I have 2 phones with identical original batteries(0722) and both will not work with any others! This is becoming extremely frustrating! I tried ordering from iFixit themselves, I love this site, but they no longer ship to Canada. Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
If you are getting a low battery icon with the original battery that came with the phone and the lightning cable plug in won't go away even after trying multiple cables and charging ports, then stop wasting your time on battery replacements and get the U2 Tristar Charging IC replaced by someone that does micro soldering.
这个答案有帮助吗?
得分 2
添加一条评论
Mobiledefenders.com will have the battery you need.
这个答案有帮助吗?
得分 0
1条评论:
Your website shows no matches for the APN I need. If you have an answer to why the suggested compatible batteries are not working, please let me know. Otherwise, I do not need a solution from another merchant that has already failed
完成的
添加一条评论
http://www.powerbookmedic.com/iPhone-5s-...
I suggest that one. You can get it new, used or grade B and it has a 1 year warranty.
Its stupid that iFixit wont ship to canada anymore.
这个答案有帮助吗?
得分 0
4条评论:
Your link shows a photo of the incorrect APN. If you have an answer to why the suggested compatible batteries are not working, please let me know. Otherwise, I do not need a solution from another merchant that has already failed.
完成的
Just get a new 5s. They are around $200
完成的
Sure, split the difference with me and I'll gladly do just that. Only it's 270$ CAD and the battery only costs 20$. So send me 250$ and I'll gladly follow your advice.
完成的
Well you said you spend $100 already on a battery. So there is more than half, along with the 4 or 5 other batteries you got. That equals the $200 if you return them all.
完成的
添加一条评论
添加你的答案
dark2400 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 102
