跳转到主内容
Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
75 个问题 查看全部
Why does my phone turn on and off by itself when battery life gets be
My phone works fine as long as it stays above 60 percent when below that it won't stop turning on and off by itself
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey Billy, sounds like your battery is having capacity issues. Lithium ion batteries are ranged to last from as little as 1 year, up to 5 or even 6 years. (Mainly flip phone batteries may last that long) It really just depends on your charging habits. Try not to plug it in until it reaches 20 percent or below and try to leave it plugged in until it reaches 100 percent capacity. If there's a local Batteries Plus Bulbs/We Fix It in your area, you'll be able to get a great deal on a battery. Order it on batteriesplus.com and you'll even get 10 percent off! Don't trust the 10 dollar ones you can buy on ebay. The battery from BPB will also be lifetime warrantied through any of their stores. They can install the battery easily for you if needed, and if the phone continues to cause the same issue, you will have a 14 day return period. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Billy Rogers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 41
