跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
微软第三代Xbox游戏机于2013年11月22日发布。
496 个问题 查看全部
What to look for when buying a broken Xbox one
I'm looking to buy an Xbox one, and I don't plan to spend more than $80 total. I see a lot of "turns on then turns of right away" consoles on eBay. What is the cause of this, and is there a good fix? Would a relfow cut it? If so, how would I go about it? Also, is this the cheapest problem to fix?
Update 5/15/17
Ok, Iv'e purchased an Xbox: http://www.ebay.com/itm/Xbox-One-PARTS-O...
All it should need is a fresh install. How do I go about this? I know how to take it out and mount, but not how to install the OS...
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 3
评论:
@tronicsfix I could use your expert advice. Thank you.
完成的
添加一条评论
2个回答
已选择的解决方案
I wouldn't get one that turns on then back off. Sometimes it's the Southbridge, sometimes the APU and many times not fixable. You should be able to find a cheap one that needs a new disc drive. That's what I would go with.
这个答案有帮助吗?
得分 6
评论:
But isn't the disk drive paired to the motherboard?
完成的
How about the ones that randomly power off. After 10 minutes or whenever. Same problems?
完成的
Only the optical drive PCB is paired to the motherboard, it is attached to the optical drive by three ribbon cables and 2 soldered wires and can be transplanted to a donor drive mech with ease.
完成的
@tronicsfix, I was looking at this One: http://www.ebay.com/itm/Xbox-One-500-gb-...
Since it has no hard drive, the E101 is meaningless? Should installing the OS on the HDD fix it?
完成的
@pccheese Yes, the disc drive board is paired to the motherboard so you don't want to buy one that doesn't have the disc drive. Most of the time the disc drive just needs the laser replaced. Even if you have to replace the disc drive you just have to transplant the board from the old drive onto the new drive.
E101 is usually fixed by putting a hard drive in and installing the OS onto it. There are lots of guides on Youtube on how to do that.
完成的
显示更多的4条评论
添加一条评论
I would personally buy the one with the power shutting off because it can be something simple like the RF module or something like a bad trace on the board. So I would buy the one with the power issue!
If you have any questions or concerns please comment below!
这个答案有帮助吗?
得分 0
评论:
Or like tronicsfix said, it could be something far more major.
完成的
Well yes possibly but if you have to replace a disc drive it can be more expensive then anything.
完成的
The disc drive tends to be simple to fix, it's generally dirty rollers or misaligned mech stoping the disc fully inserted it the laser needing replaced. Either fault is not very expensive to repair.
完成的
The RF module rarely causes any problems...it's very common to have the SB chip or APU be bad with the on and off problem. The board having a "bad trace" doesn't happen on it's own. If it has a bad trace it's because someone opened it and caused the bad trace.
The disc drive is usually easy and cheap to fix. Many of them need a $10 laser and they're good to go. If you have to replace the entire drive it gets more expensive but that's rare.
完成的
@tronicsfix that is very true but bad trace can happen when the board gets hot! This can happen if the fan goes bad and the heat sink will get extremely hot!
完成的
显示更多的4条评论
添加一条评论
添加你的答案
George A. 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 13
过去的30天: 75
总计 3,009
