跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 Long screw damage
Hello!
I changed silent button on iphone 6, then i put display back, turn on phone and start putting esd shield. I put 0,1mm longer screw in down left hole, i heard cracking and when i heard cracking i tako out screw. I put back screen and start testing phone. At one moment screen comming black and turn off completely. I connected phone to itunes, itunes recognized it, but screen is black. Its not backlight problem i saw. I put new display but same again. I force restart it, disconected battery and all that i found on the web.
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What state/country are you in? You will have to sent it to someone who does microsoldering.
完成的
添加一条评论
1个答案
已选择的解决方案
Unfortunately, it sounds like you have Long-Screw Damage. If you want to be certain before sending your logic board out for repair, I would start by testing a bare-bones setup. Start by disconnecting the battery first (always!). Then disconnect the digitizer, LCD, front camera, rear camera and home button extension flex (see this guide). Now re-connect the battery; you should only have the battery and Lightning Dock flex connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer.
If you have access to a multimeter, you could measure the battery first. If it reads ~3.8V - 4.2V, then it is good. Does iTunes recognize your phone? If so, then you should re-connect one flex at a time until the phone stops working. I would start with the Home button flex first, then add the rear camera, LCD & Digitizer then from camera flex.
If the bare-bones setup does not get recognized by iTunes, then you most likely have a logic board issue. You could send it (or find a local) to a repair shop that specializes in micro-soldering repair. Many shops offer mail-in service and offer a no fix / no fee policy.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Aleksandar Lukic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,184
