跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why is my iPhone 5s volume silent ringer switch not working?
Okay hi guys.
Having trouble with yet another iPhone 5s. Before we start I have already replaced the wholes cable but still the switch isn't working.
Everything else on the same cable seems to be working great except the silent ringer switch.
Any ideas please comment below.
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Small parts, such as button flexes can be low quality. I would certainly try another, known-good flex to completely eliminate this variable. However, if a known-good flex does not work, then your problem may be on the logic board. You would want to probe FL7, which is the filter in line with the Silent switch (look it up on the schematic, which can be found on the web). If it is partially dislodged, damaged or missing, it will cause the same problem.
这个答案有帮助吗?
得分 2
1条评论:
Hi i have not got very good knowledge on this. Do you have a link to share with me or something where i can fond more info. If this isn't the issue what else could it be?
完成的
添加一条评论
添加你的答案
Rakesh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 791
