跳转到主内容
The Nikon D700 is a 12.1 MP FX-Format CMOS Digital SLR Camera with a 3.0-Inch LCD.
14 个问题 查看全部
LCD started not to work. Only black with grey lines on LCD.
My Nikon D700 LCD screen suddenly quits.only black and grey lines can be seen on LCD..it all happened when my battery power pack displayed low battery.turned it off and took out batteries and replaced . Then when I power back on LCD started turning black then grey lines.now camera is unusable because the LCD monitor is out.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have the same Problem, i think it happend in 2018. I connected a non Nikon Brand battery grip and suddenly the display turned black with white lines. It is still possible to use the camera with external monitor.
But maybe meanwhile someone knows which part i have to replace to fix it and wake up camera from Death after Years.
完成的
添加一条评论
1个答案
最有帮助的答案
Sounds like the LCD connections​ are loose. Luckily, there is a service manual that shows how to open it. Nikon_d700.pdf
Open it up, unlock the ZIF locks, clean the connections with a microfiber cloth, put the ZIF back in, flip down the lock, and you should be good to go!
If that doesn't fix it, it must be the logic board or LCD.
Hope this helps!
这个答案有帮助吗?
得分 1
1条评论:
thank you for your help..on my testing and trouble shooting..the grey lines are changing patterns whenever i push any buttons,and also in live view meaning lcd is running but not representing the actual picture it should be doing.it has something to do with my external battery grip..maybe a voltage fluctuation ruined some parts or affected the lcd screen..
完成的
添加一条评论
添加你的答案
bolo_racing 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 526
