跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
145 个问题 查看全部
Slowly charging. Yes I looked for this
I've searched and searched, and no one seems to have a good answer. I already replaced the charger port. Is the new part faulty? Kinda goes against reason that the initial one failed, and so did the new one. But it charges slowly/won't charge. I'm trying the disconnect battery, reconnect, remove display cables and plug in charger method right now. I could easily see this being a software issue. However not only am I locked out of the customers device, it's all in Spanish. Wanna get this figured out, anybody?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
评论:
Bumping for great justice
完成的
Just gonna bump, really haven't found anything helpful
完成的
添加一条评论
1个回答
How many volts and amps is the charger your using?
Also, if you can provide a photo of the data on the charger that your using and also the back of the tablet near the charger port where there may be some icons and text.
这个答案有帮助吗?
得分 0
评论:
It's not the charger, and I already replaced the charger port
完成的
添加一条评论
添加你的答案
iMedic 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 336
