跳转到主内容
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120 个问题 查看全部
forgot my pin number
how can I bypass lost pin number
Update (05/10/2017)
I have a Samsung galaxy note 3 model number is sm-t210 can I get in without loosing everything by doing a factory reset ????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 19
11条评论
Look at what i posted. I have multiple options on how to do it.
完成的
How to unlock a pin code from screen
完成的
i forgot my 4 digit pin to my samsung galaxy tab how can i know what is the password
完成的
How can I unlock my Samsung Galaxy tablet for my pin number
完成的
I forgot my 4-Digit pin to my Galaxy tablet how can I recover that without hard booting it and losing all my information
完成的
显示更多的6条评论
添加一条评论
7个答案
最有帮助的答案
https://android.gadgethacks.com/how-to/7...
There are a few different ways that do not involve data loss.
I hope this helps! If it did please hit accept answer!
这个答案有帮助吗?
得分 6
添加一条评论
The only way to bypass the unlock code is to factory reset your tablet, you will loose all your data though.
1. Power off your device.
2. Boot in recovery mode by pressing and holding Volume Up, Power Button and Home Button at the same time.
3. Release all buttons when the Samsung Galaxy Tab 3 Lite 7.0 screen flickers and in a few seconds the Recovery screen will appear.
A menu will appear use the volume up/down buttons to navigate to Factory Reset option and press the power button to accept, select OK/YES from the menu the proceeds to Factory Reset your tablet
这个答案有帮助吗?
得分 4
3条评论:
yes its very helpful for me
完成的
I cannot switch the tablet off without the pin number?
完成的
Not helpful because it doesn't work on every tablet I did all this and the pin is still there
完成的
添加一条评论
I was able to fix mine using the pin # 1234.
这个答案有帮助吗?
得分 4
添加一条评论
It says draw of directions to unlock screen
这个答案有帮助吗?
得分 1
2条评论:
What I want to do is to unlock my Samsung Galaxy Tab
完成的
The tap says draw series of directions to unlock screen
完成的
添加一条评论
More than a year now
这个答案有帮助吗?
得分 0
2条评论:
What does score 0 mean?
完成的
Am failing to understand score 0
完成的
添加一条评论
Hey Luke you need to do a hard reset this may not work but try power off then push volume up and power button for about 4 sec. if it trys to power back on go 3 sec. what you want to do is get the robot on there and volume buttons up and down will guide you to reset enter will be power button good luck
这个答案有帮助吗?
得分 0
添加一条评论
Somebody gave this tablet the The Samsung Galaxy tablet 3 but the person does not remember the PIN number so how can I get in it to break the PIN number so I can open up the tablet
这个答案有帮助吗?
得分 0
1条评论:
How can I get into Samsung Galaxy tablet 3 when the person that gave it to my son doesn't remember the pin number which is a four number code how can I get into it to open it up and it won't allow me to do nothing
完成的
添加一条评论
添加你的答案
Luke Matthews 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 38
总计 47,408
