My watch does not turn on. I get wet with water. It only vibrates in..
My watch does not turn on. I get wet with water. It only vibrates in the charging base. Can it be the battery or some other component? When I touch the screen it vibrates but it is black. I hit the power button and vibrate. I disarm and only connect the battery to the main board and do the same. Do not even connect the other pins as the main screen. Which of the 4 components can be damaged? The battery The battery is almost 2 years old. The screen is oled? LG W110 Black Center Frame? The main board I think is the mainboard? The back cover would almost certainly discard it. I hope they can help me to buy the correct answer. Thank you so much.
2条评论
Hola! Despues de unos días mi pantalla encendió pero solo esta visible cuando lo pongo en el cargador.
Cuando lo saco del cargador se apaga al instante. Supongo que con esta señal puede ser la batería dañada no?
Que opinan?
由 golfsilver2006 完成的
Hello! After a few days my screen went on but it is only visible when I put it in the charger.
When I take it out of the charger it goes off instantly. I suppose with this signal can be the damaged battery no?
What do you think?
