跳转到主内容
LeapFrog Leapster learning system, older model with stylus pen.
3 个问题 查看全部
Where can I get my device repaired?
Can anyone PLEASE let me know where I can get my device repaired?!?!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
12条评论
Hi,
What is the problem with your device?
完成的
Yeah I got it for $7 at a goodwill. Just wanted to see if I could fix it. The main issue is that batteries were left in it that leaked over a long time...
完成的
I remember when I had one of those.
完成的
@ah1234 on here we try and help you fix your own device. You are empowered!
完成的
Well lmk how?
完成的
显示更多的7条评论
添加一条评论
1个答案
已选择的解决方案
@ah1234 sounds like the battery contacts may have either been to destroyed by the alkalinity of the old batteires or just not making good contact with the rest of the Leapster. You can clean the contact with some vinegar on a cotton swab (may have to repeat this a couple of times depending on how bad they look). Once properly cleaned check to see if you have better results with new batteries. If not, then you will have to open the leapfrog. Try the instructions from here. Take plenty of picture while you do so. You need those to reassemble the device and/or make a guide for the rest of us by following these steps. you can also post those images with your question, by using this guide so we can see what you see.
这个答案有帮助吗?
得分 6
1条评论:
My son's LeapPad 3 the screen keeps displaying that it needs to be updated buy a computer we try to update it and it did not work where can I take it to get it fixed
完成的
添加一条评论
添加你的答案
A H 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 473
