iPhone 5S A1457 stuck at "connect to itues"
Got an Iphone 5S that been sitting here for a while, now i pulled out and not sure what could be wrong. It just shows "connect to itues" and it wont update, DFU mode seems not to be able to restore/factory restore it eighter.
And i cant see any error msg from itunes
Any tip out there ??
5条评论
When you connect to iTunes, does it recognize it?
由 Gigabit87898 完成的
Yes, shows SN, Iphone and name on it. Statens that i need to restore or uograde
由 thomas 完成的
Did a test With 3UTool and got to 20%, then phone "rebooted" and it stuck there. Screen did a red flash then black and reboot. Tested 3-4 times.. Gets to 19%.. Starting to think it might be faulty NADN :-(
由 thomas 完成的
Try unplugging the front camera, for this you will need to open up the phone and restore again.
Hopefully that will work because if that does then the front camera assembly is faulty.
You will probably need to replace it as shown here (Damaged cables cause can cause the phone to not boot up):
iPhone 5s 前置摄像头和传感器排线更换
由 Ben 完成的
Front flex has been removed, testet With a New screen without front cam, still no Luck :-(
由 thomas 完成的
