跳转到主内容
Repair guides and support for motorcycles manufactured by Harley-Davidson.
72 个问题 查看全部
makes a loud screeching sound when trying to start
Mine makes a loud screeching sound when trying to start 2007 roadking
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Could be the bearing is gone in the end of the starter . Pull the starter and spin it while not engaging the engine to see if the screeching is in the starter or if it is in the engine. if its runs silent then the problem is in the engine if the screech continues when the starter is run when not in the bike means you need a new starter. Hope this helps
这个答案有帮助吗?
得分 3
添加一条评论
If it's screeching and not turning over the engine, then most likely the starter clutch is blown out. The part is available separately, and the starter motor has to be removed and disassembled to replace it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bryant Coleman 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 17
过去的30天: 70
总计 3,451
