跳转到主内容
Announced on July 2015, this is Motorola's flagship phone. It has a 21 mega pixel camera with a 5.7 inch IPS TFT LCD screen with a resolution of 1440 x 2560 making it Quad HD. Model number XT1570, XT1579, XT1575 and XT1578.
Battery charging issues. Recognizes it but doesn't charge.
Alright, I've posted a similar question, but that one got lost in the abyss that is tech problems.
Alright, so a few months ago i dropped my moto x and the screen shattered. I got all the parts, fixed it, and the screen is functioning like normal. The main problem is that the battery will drain extremely quickly, and the phone will not charge. The phone recognizes the cord as plugged in, but the battery menu says not charging. I have tried two phone chargers, both do not work. I have cleared cache, soft reset, and still nothing. The front flash is also missing, which i was thinking might cause the battery to discharge quickly. I have already replaced the battery, and it still has the same problem. I am beginning to think that it might be a charger port problem, or maybe even a problem with the logic board. (maybe even flash? who knows?)
Also if anyone has a good suggestion in how to glue the screen to the frame of the phone that would be great thanks. (1mm 2 sided tape is not doing the job)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Did you find a solution? I'm facing the same problem! Thanks
这个答案有帮助吗?
得分 0
2条评论:
Sorry no, I've brought my phone to a store and they said they couldn't fix it. Even if it was a problem with the logic board, I don't have the tools to fix it.
完成的
Thank you for the answer!
完成的
添加一条评论
I have the same problem too, when i tried to get fixed in service center, its too expensive. So if you guys have any solution, post it here.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
H4N2 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 706
