跳转到主内容
谷歌手机维修指南。
1230 个问题 查看全部
Touch doesn't work after screen replacement Google Nexus 5
I had a cracked screen and I replaced it with a new screen. It powers and I can see the notifications and other aspects. But the touch worked for few minutes and has stopped working now. I tried reassemble the screen again but it was not of any use.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Check that there is no damage to the pins on the screen and daughterboard connectors as they could have been damaged by the repair. If they have been you will need to replace either the screen or the daughterboard depending on which is damaged.
Otherwise it is probably a faulty screen, you'll need to get a new one to test.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 134
