跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
M.2 SSD Installation iMac 27 "5K Retina
Hey,
Is it possible to install Samsung 250GB 960 EVO SSD, M.2, NVMe, 3200/1500 MB / s Apple iMac 27 "Retina 5K, late 2014?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
They just don't seem to work very well even with the adapters. I would stay with either an original Apple stick (high dollar) or go with an OWC stick (I don't think they make one yet for this model as they only list these upgrades https://eshop.macsales.com/upgrades/imac...).
It's also very difficult to install: 27英寸 5K Retina 显示屏 iMac 固态硬盘SSD 更换
Personally I'd add just a standard SSD drive like this: How to Add An SSD To The 27" iMac (Late 2015)
iMac Intel 27" Retina 5K Display Blade SSD(固态硬盘)更换图片
指南
难度:
困难
2 hours
iMac Intel 27" Retina 5k Display Replacing the SATA HDD for SATA SSD图片
指南
难度:
中等
30 minutes - 1 hour
这个答案有帮助吗?
得分 4
8条评论:
Hey,
thanks for the answer. What kind of SSD do you recommend to iMac, which would be quick and easy to change?
完成的
See the last link I gave. As to which drive, it's kind of according to how much storage you need, how readable it needs to be and if you plan on setting up a fusion drive. The fusion drive would be my choice.
完成的
Thanks for the answer. I have a 1TB Fusion Drive on the Mac but it's very slow? Can Fusion Drive and SSD Partition Separate?
完成的
First get a handle on how a fusion drive works: http://www.makeuseof.com/tag/what-is-app...
完成的
Thanks for the information. I read the article. Say your opinion on whether it makes sense to switch to Fusion Drive -> SSD?
Is it possible to distinguish Fusion Drive from SSD, partition etc ..?
Thank you mayer!
完成的
显示更多的3条评论
添加一条评论
I replaced my stick and its not a change at all I get the 1 Terabyte but the speed is about the same just volume gain thats ok. I never had a fusion drive so I did get to put in a 500 G where there was none, thats a gain to and faster than external by just a bit. The NVME is better off on the outside if you have a fusion drive inside its a easy change up.
If there is going to be a Firmware update to stop the bottlenecking on the 15,1 27” iMac then we will see a gain.
Personally I thought the process of putting in a new SSD was very easy I had to add the cable and heat sensor so if I was going all the way I threw in the new stick too. Yes, you're going all the way in, so really if you follow the fix it instructions its easy. I would do it again in a minute. Biggest worries don’t drop the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Riku 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 8,419
