跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
Left Speaker pops & looses its bass/mid frequencies
So suddenly my left speaker lost its bass and mid frequencies, and only hi / thin sounds are coming from it. Right one works well.
Sometimes when an hour or two passed in mute, and i start a music , i hear a POP sound from the left side as soon as I higher the volume and quickly it looses its power as described.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Apple has a warranty repair for this! Bring your system in to an Apple Store or authorized service center.
这个答案有帮助吗?
得分 2
5条评论:
I live in Lebanon and bought this online from Dubai, do you think im still eligible?
完成的
Good Question!
Here's a listing of the local Apple Stores, you'll need to ask one of them.
完成的
Outside the Apple warranty is there any other know fix to this problem ?
完成的
As the system is so new parts are difficult to get.
From what I understand the issue is two fold a firmware issue and a blown speaker from the bad firmware.
完成的
All the research I've done says it's a blown speaker or amp issue.
after taking it in to Apple they quote a $600 repair to replace the entire top (keyboard etc) to fix it. If the keyboard has gone they will do it for free while their 2016 keyboard recall is in place. My keyboard is still working fine. There is a Audio Midi Setup App. If you select Built in Output and change the Format: from 44,100 Hz to either of the two choices the sound will come back until the volume exceeds what the speakers or amp can handle and then the sound will degrade again. The Genius bar guy suggested that I call Apple Care to see if I could convince them to repair it gratis or perhaps at a discount because it is a known issue but not covered if your warranty is already expired. I haven't done it yet, I'm holding off of the disappointment and time investment to have this call.
完成的
添加一条评论
So Apple said my warranty is gone because there is a TINY scratch/damage on the right side that has nothing to do with the left speaker!!!!
这个答案有帮助吗?
得分 0
1条评论:
Go back and speak with the service manager! Thats crazy!
完成的
添加一条评论
添加你的答案
Serouj Baghdassarian (C-rouge) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 4,508
