跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Repair guides and support for motorcycles manufactured by Yamaha Motor Company.
59 个问题 查看全部
2013 V-Star 650 engine stall at engaging gears
With the side bar up and the clutch lever pulled the engine stalls when You engage the gears. It started after an oil change where I used Valvoline durablend 4T semi synthetic oil for motorcycle . I suspect a malfunctioning side bar security switch but not sure.
The motorcycle has only 48 miles run, almost new.
Could it be a clutch malfunction? I already adjust the clutch cable.
I brought the motorcycle from USA to Belgium.
Please, some idea will be very welcome.
Regards
Hector Alfonso
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
@hmalfonso the model on the bike itself, is it a XVS650?
完成的
Is your problem solved?
完成的
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
2个回答
已选择的解决方案
@hmalfonso could be that this is caused by a bad side stand switch. Should be easy to figure out with a multimeter. Location of the switch is marker 19 on the diagram
Here is how to test your switches for continuity etc.
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
Im not completely sure on this as to if Yamaha ever had this but over the years Ive had bikes that had a level sensor so the bike can't be put in gear if the bike was leaned to far to one side. sort of a backup for the kick switch . Ive also had problems with the kick switch if the spring doesn't hold the kick all the way up . If the kick switch was malfunctioning would it even let the bike be started ? I would defiantly check that the switch is adjusted to make contact correctly when up. If you don't have a double kick then you'll need a friend to help with this to hold the bike up. Hope this helps a fellow rider
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Hector Alfonso 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 16
过去的30天: 56
总计 1,538
