跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Radio controlled clock runs an hour fast
A few years ago we bought a radio controlled analogue clock for my elderly mother-in-law which sets itself automatically from the MSF Rugby time signal. It seems to be this one: http://www.argos.co.uk/product/2552790
It successfully reset itself to Summer Time when the clocks went forward, but is now showing the time plus an additional hour. There's a "REC" button on the back which causes it to re-sync with Rugby, and when I pressed that it did indeed resync, but again, to an hour fast.
I haven't tried taking it apart, and wonder if anyone else has done so and can explain the behaviour. I suspect that behind the clock face it must have a series of circular tracks with contacts which allow it to detect where the hands are, or just 2 contacts which are closed when the minute and hour hands respectively reach 12 o'clock. Maybe the minute hand contact is dirty and isn't always detected. Can anyone, having taken one of these apart, throw any light on this?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Have you tried leaving it unplugged for like 10 minutes?
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
3个回答
已选择的解决方案
I have the same problem; same “REC” button, same exactly one hour too fast. Simple solution was to remove the front cover, which was clipped on so just required a bit of a tweak to remove, and then remove the hands and re-position them to the correct time. It works! :-)
这个答案有帮助吗?
得分 0
评论:
But then does the Rec button still initially set it to midnight, or to 11:00?
完成的
Since I posted the original question around 18 months ago I'm struggling to remember the details, and my wife can't remember either, but I've disassembled at least one other radio controlled clock. From my recollection, it wasn't quite as easy as taking the hands off and putting them back in the right position, I think maybe because it isn't easy to put them back without moving the spindle away from the reference position (12:00).
Disassembling a couple I found that the way these clocks find their reference position is by holes or spokes in the hour and minute cogs which line up with an infra-red LED and detector at the reference position. I saw two different designs. If you remove the cogs you then have to position them correctly on reassembly. This led me to wonder how they're manufactured in the first place. In fact I found the critical cogs had pinholes in them. Putting pins through them enabled me to fit the hour and minute hands correctly whilst holding the cogs in position.
完成的
添加一条评论
最有帮助的答案
See my comment on @chr15williams answer. This photo, which I took at the time, shows how I held the cogs in their reference position while refitting the hands. The pins pass through holes in the cogs lined up with holes in the case. I did eventually fix my mother-in-law’s alarm clock and it’s still going.
这个答案有帮助吗?
得分 2
添加一条评论
Try replacing the one AA battery.
这个答案有帮助吗?
得分 1
评论:
Obviously the first thing to try, and these clocks do need good quality alkaline batteries, not zinc or rechargeable. But mine's batteries were good.
完成的
Sometimes we overlook the obvious as to simplistic, I know I have ;-)
完成的
添加一条评论
添加你的答案
Philip Le Riche 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 19
过去的30天: 110
总计 1,669
