Hi @dylan734 ,
Have you spilled any liquid onto the keyboard?
If not, have you checked that there is not a stuck key (half operated) on the keyboard? Take a close look and also operate each key a couple of times to ensure that they all operate/release correctly. It is a pain I know but it only takes a little bit of time.
Have you checked the keyboard settings in (if Win 10) Settings > Ease of Access > Keyboard, especially 'sticky keys' (If not Win 10 Ease of Access Centre is in Control Panel)?
Plug in a USB keyboard to prove whether the problem is hardware or software related.
I only mention 'software' as 'resetting' means different things to different people. e.g. restoring using a system restore point, re-installing back to initial installation, restoring using a system image etc.
Hi @dylan734 ,
Did you try a USB keyboard?
If that works OK then most probably the keyboard in the laptop is faulty. It is easier to replace it than to try and fix it as you can cause more problems than what you had when trying to fix the problem.
Here's a link to a video that shows how to do it.
Just search online for an Asus A45V keyboard to find suppliers of the keyboard.
4条评论
@jayeff Not that I know of its a shared PC.but I realize that then I press the caps lock button it also presses the tab button hope that will help.
由 Dylan Yeong 完成的
im having several issues with this KEY MIX UP PROBLEM ASUS R544L
由 Donna Green 完成的
i need to know to fix a ASUS computer if you drop gas on it. We where on 75 MPH and we crashed and the gas the gas drop down to the computer. that is all i want to know how to fix it.
由 Josue Velazquez 完成的
You have to change your laptop keyboard or try to use an external keyboard that way you can check it works for you or not also if it's then you should also try the sticky key option in your windows 10 follow the link: https://www.skytechosting.com/turn-off-s... or reset your old settings...
thanks
由 King Jamesgateway 完成的
