跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
258 个问题 查看全部
Water damaged touch bar playing up
Okay so i got my lovely macbook damaged by the rain the other week, and took it to a repair shop who said that it wouldn't even turn on and is 'uneconomical' to repair. However when i got back i put it near a heater for a few hours and now everything on it works fine (apart from a little bit of screen damage but thats livable), the only thing that doesn't work is the touch bar, i cannot use it and more importantly, it randomly selects buttons by itself every 20 seconds or so. Is there any way to disable or relace the touchbar? what would happen if i just cut the cord?
thanks for your time
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
hey James.
As it turns our, the touchbar is essentially impossible to replace by itself as it's glued to the top case.
The only way to truly repair the computer is to have apple send it out for repair which I think is like 1600 bucks... :(
这个答案有帮助吗?
得分 0
添加一条评论
it could be a connector? did you ever get this fixed and find out what happened? having the same issues.
这个答案有帮助吗?
得分 0
2条评论:
Hello
The laptop ended up dying from the water damage so never got the chance to cut the cable and see what would happen
good luck!!
完成的
@james.harwood5 gotcha thx
完成的
添加一条评论
nothing should happen if you cut the cord. but if you invest in a top cover witch holds your keyboard and touchpad it has a lot of scews and needs to be put perfect and mind the fact it has to be identical to the apple mac book for this to work. just requires alot of attention and detailed take apart and reassembled. if you havent took one apart dont advise you do it. might just be worth adding a usb mouse and keyboard for the cheapest method in a fix. is all i could say. hope this works for you.
这个答案有帮助吗?
得分 0
添加一条评论
Hey did you get the solution to this? My touch bar on my ipad has some water too, and it randomly starts playing around with the controls.
Let me know what you did and if that helped!
这个答案有帮助吗?
得分 0
1条评论:
Hello. No it stopped turning on before i had the chance to cut the cord. It is upto you what you do, but looking back i wish i just sold it and cut my losses.
Good luck!
完成的
添加一条评论
添加你的答案
james.harwood5 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,166
