跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
No wifi/ bluetooth upon reassemble. Gps is off on maps
Hi, I recently replaced the screen on my iphone 6. I disassembled the phone by removing the screen, attennea and did remove the logic board at one point to tinker and understand the hardware. The same phone did have some hefty damage.
Moreover, everything works fine upon reassembly with the exception that my phone does not have the ability to connect to a wifi network, bluetooth, and gps maps is off on both imaps and google maps.
What are the appropriate steps to troubleshooting the device? I want to resolve the issue? In most cases are bluetooth seperate issues vs. wifi and is the maps happening due to a latency on the ping with the server because it does locate me. However, no wifi IP would also address the issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Your ios version?
完成的
添加一条评论
1个答案
已选择的解决方案
Most likely damage to the Logic Board Antenna flex cable. Replace that one and it should be working 100%.
iPhone 6 Logic Board Antenna Flex Cable
iPhone 6 Logic Board Antenna Flex Cable图片
产品
$9.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Stephen Sizensky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 88
