跳转到主内容
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
135 个问题 查看全部
My Samsung Galaxy Tab 4 will get stuck on the samsung logo!
I was using it the other night and it was rooted because I accidentally deleted an important file so I was trying to get it back but then my tablet reboots by itself and then It would not properly start up it would get stuck on the Samsung logo animation I have already tried to wipe the device and it still refuses to work PLEASE HELP!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You just messed with some system file which are necesary for android os to boot , before doing any thing make sure you make an ndroid backup through recovery!!!
If you have a backup simply restore it
If you dont have backup you need to flash stock frimware or custom rom if your recovery supports it...(otherwise use samsung's pcsuit app ,i forgot its name maybe odin )
Remember not to wipe data (if your data does matter)
这个答案有帮助吗?
得分 1
5条评论:
Ok, I will try to thank you.
完成的
I plugged in my device but my computer nor odin will recognize it.
完成的
Follow these steps . As your device boots you should be able to flash (i hope your usb socket is ok)
https://www.kingoapp.com/root-tutorials/...
完成的
I am trying it right now again thank you
完成的
Thank you so much it working I just didnt plug it into my computer properly so it would not read it. My tablet is working now. :)
完成的
添加一条评论
添加你的答案
Akif Rahman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 3,284
