Why bike wont start
I have a 2013 thunder bird 1600cc sometimes starts with no problem, and other times power to gages and fule pump but when i hit the starter nothing not even a click?
@hectorpez ,Hector, That could be signs of a battery on it's way out or bad connection. Have battery tested, check all connections and wires for not being loose/corroded/damage in the starting circuit/on battery. See the link below as it discusses your issue. I have also attached a down loadable service manual at the 2nd link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 5
过去的30天: 37
总计 1,673
Check for correct gap of sparkplug (s) and proper plug size
由 Robert Johnson 完成的
