跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
I need to replace just the button only
My button is cracked only, but works, I replaced the screen, came with a new home button now I need to replace just the button only there is some solder pads there, can you unsolder just the button from the module and solder it to the original home button assembly?
Please advise urgently.
Mushtaq
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Just replace keytone, not solder.with multitester, check line homebutton in flex cable
这个答案有帮助吗?
得分 0
2条评论:
How do I remove the button only, I don't understand please advise.
Mushtaq
完成的
I need to use the home button assembly from the original screen for ID touch but the button itself is cracked is it possible to remove and fit a new button that came with the new screen, thanks, Mushtaq
完成的
添加一条评论
添加你的答案
Mushtaq Mahomed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 45
