跳转到主内容
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
240 个问题 查看全部
Why the Nintendo DSi powers up for a second then shuts off?
Battery is fully charged, but the device powers up for a second then shuts off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个回答
最有帮助的答案
has the unit been droppedt? If it has the top screen is busted or the power fuse has been broken off the motherboard and requires it to be resoldered on. If neither of the these has happened then the top screen has went bad and needs replaced.
这个答案有帮助吗?
得分 1
添加一条评论
You might find this article here on iFixit useful if you're going to replace the top LCD screen. Hope you can resolve your problem.
这个答案有帮助吗?
得分 1
添加一条评论
Check the power fuse. If broken it prevents the DSi from coming on. http://m3wiki.com/index.php/Nintendo_DS_... shows you what to look for and how to do it....Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charles Browning 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 3,103
